anyone knows why sometimes my speedo meter dies for les than a sec then comes back on
as if like i toke the key off the ignition and turn it back on
while im driving
is there some thing wrong ???
kinda worried
and it happends from times to times kinda often tho
Have you checked the plug? With humidity, vibrations, etc.. maybe it got corroded and the contact isn't 100% anymore.
A friend of mine had the same prob, accept his would go off for extended periods of time. It ended up being a wire coming unsoldered from the circuit board inside the instrument assembly , good luck with it.
Banned
HEY THERE EMAZENS, I HAVE THE SAME PROBLEM AS YOU, I'VE HEARD THAT IT MAY BE THE SPEED SENSOR THAT MAY NEED REPLACEMENT. TRY THE OBVIOUS (CABLE CONNECTIONS) IF NOT, MORE THAN LIKELY ITS THE SPEED SENSOR. I'LL LET YOU KNOW IF THAT'S IT (I'M WORKING ON MY BIKE TOMORROW) OR LET ME KNOW IF YOU DO IT FIRST. GOOD LUCK.
no problrm man
well i didnt do anything on it just just stoped doing it since i stoped putting any water to wash my speedo
i dunnu
