Discovered a new problem with my new soul mate (my 929 :D). Now the winters drawing in in the UK I've discovered the turn signals don't work when it's cold !
Strange problem ?? If I press the switch there can be a 10 second delay to the indicators working if they come on at all. Obviously this could prove a little dangerous.
Any one else seen the same? I'm guessing the turn relay could be a bit past it? assuming they're mechanical relays and not solid state?
No. That probably would have cured it completely. I just gave it a huge blast of WD40. If I'd had brake cleaner I would have used that instead.
