hello all, I have a 2001 cbr 929. anyway I put a new clutch basket on and new fairings and got tank painted, I put it together it started and ran for a min but ran rough I tried to start it the next day and nothing! I can hear gas pump prime, smell gas at exhaust but not wanting to fire! could the pulse generator (also may have gotten some gasket maker on the front of it when I was putting cover on)be bad from when I took it off or put on wrong? I also took the two small vent hoses on tank and swapped them and no fire still??
Re: cbr 929 wont start
could be flooded??? I have flooded mine but I have 954 throttle body's, injectors and pc3 on mine. not tuned yet, so it runs rich and can flood...
If it ran fine before then take it back apart what ever you did there is your problem. So just check everything you did. Even if you have pull side cover or tank again.
