1 - 11 of 11 Posts
Hello I have a 2000 929 that I'm working on , it ran before winter , someone cut the kill switch wires and the ignition wires , I fixed all the wires I found cut , all the switches are working but the fuel pump will not turn on , tested pump and it works , tested computer in another bike and it works , changed all relays , checked and changed lean sensor , changed all four wire harnesses and gauges , checked all fuses and grounds and still nothing , I did not change stator , rectifier , crank or cam sensors , I'm stumped / lost please help
Check for 9 volts on the pink wire at the ignition switch (key switch)
I have checked safety switches .
I have tried 3 ignitions one of witch was brand new and didn't make any difference , I will check the voltage next time I work on it .
Do you have spark?
Not throwing any MIL on the dash?
Tried bypassing the kill switch?
Coils and injectors have power , won't fire at all , injectors won't fire ether with pump hit wired , kill switch has Ben checked ( all wires have power when it's on ) , no codes
How many volts on the pink wire coming from the key switch? Not "it has power", need to know the voltage
I don't know the voltage yet I haven't been back to the guys house to work on it again , I'm trying to get a few thing to look at b4 I go back , what is the 9v for ?
tells the computer its ok to turn on fuel pump. until you get that working without being jumped you should go no further.
It was the ignition switch even the new one was bad took mine out of the 954 it in and everything works , thanks everyone for all the help
1 - 11 of 11 Posts
