Hi, thanks for answering me. Perhaps I got the 954version. I bought the regulator new from Germany. So I will try to ask them. I started the engine after finishing change it. Now i got 18,8 voltage. Its overcharging. Maby its bad grounding . I had to travel for work for 14 days so I can't check. Just have to wait to i get back home. Could you think og any reason why the voltage is so high?Hi , I know the 954 has this configuration on the Rec/Reg , the Black from the Rec/Reg feeds the Fuel Cut Off and Engine stop relay via the Black/White wire ,but the 929 doesn't have the same configuration (no Black wire) and a different wiring diagram, so it appears its a live feed, have you tried it without the Black wire connected, or maybe get them to swap it for the 929 version
Thank you for the file you attached. I will check it when I come back to my home and bike. 👍🙂Wouldn't leave that 954 R/R on though , your battery isn't going to live very long at that voltage, check the system out including the Earth, check it alongside this
Resurrecting this as I have a similar question.The Black Wire in the R/R is a switched live ,so I dont think thats your problem
