So I have a 01 929rr. Pretty much all stock. I washed it one day then crunk it (ran fine) pulled it in the garage parked it, came back out the next day tried firing it back up and it won’t start. It will hit every once in a while and try to fire but never actually cranks. So I read some forums and they all said stator or rectifier so I changed both. Put it all back together and still the same results but now my starter will stick turning over even with the key off and out and the kill switch on the bars off untill I unhook the battery. I’ve tried unhooking all wire connecters and blowing them out thinking they might have water or somthing in there but still the same results. I’m lost...
