929RR FUEL PUMP CONTINUOUSLY PRIMING!
11206 Views 28 Replies 8 Participants Last post by  desmillie6969
3
Hello everyone,
My name is Vladimir and yesterday I bought my first Fireblade :clap::thumb:, 2001 CBR929RR with 22k miles, pretty clean except for a dent in the gas tank and some minor scratches. Here is the issue: when I turn it on there is a click and the fuel pump starts priming however it doesn't stop running after couple of seconds but continues to run after the priming is finished! As the pump continues to run I hit the start button and the engine starts and idles fine. Also a red light flashes on the dash display. I asked the previous owner about this and he says he never bothered to look into it because the bike always ran fine. Now my question is: which component in the system tells the pump to stop priming (until the engine is turned on)? Is it the fuel pressure regulator, fuel stop relay or something else? :idunno: Any help would be very much appreciated....:rotfl:Thank you
See less See more
1 - 20 of 29 Posts
It could be the diaphram inside the FPR, but there are a couple other places I'd check first: #1 the Fuel Cut Relay #2 the handlebar mounted kill switch. If the PO used the bar kill often (bad move), it may need to be carefully taken apart and cleaned. Good luck and please keep us informed... especially after you get it fixed :deal:
The thing that controls the priming signal is the ECU.
I had the exact same issue when I bought my CBR929.
Turns out my ECU was broken and so the previous owner connected the fuel pump so it was always on.
Best thing to do is get the wiring diagram off this forum (http://www.fireblades.org/forums/honda-fireblade/86073-929-954-wiring-diagrams.html)
Thing to check is the fuel cut off relay. The headlight relay behind the screen is the same relay so you can unplug that and try that ;)
The ecu controls the relay to tell it to prime/supply fuel or not.
If you cut the power to the fuel pump the bike will die. So I guessed it needs to run anyway.
I'm sure the brown wire that goes back to the ecu should ground/earth so that the 12v on the black cable (also connected to the fuel injectors) can complete its circuit. That way it then allows the relay to turn of and supply fuel.
Let us know how you get on :)
See less See more
oh and the fuel cut off relay is under the tank beside the seat along with the ecu
Thank you guys for your quick replies, I will check all the above mentioned components as soon as I can and report back all my findings.
What was the result of this? This is exactly what my 929 is doing. My FPR is good. My relay has been swapped and is good. My cut of switch has been already re-soldered from previous fix and is good. :huh:
I would really like to know before buying a ECU as that's my next more expensive check.
Thanks anyone!
The OP hasn't been online for about 10 months. So they registered, asked their question and two days later (from registering) was their last visit.
No MIL or codes stored in the ECU?
No codes....Like others I have read up on....It did run but takes a lot of cranking to fire off. The longer it sits before trying to crank, the harder it is to actually crank. It smells of gas almost like its flooding out. I can't get it to crank now but it pops off every so often acting like it wants to. Driving me crazy! When it does fire off it runs like a bat outta hell as the pump is continuously running as it should. Whatever cuts it off after a few seconds is not obviously working. :idunno:
No leaks anywhere? Have you verified spark? Verified compression?
How long have you had the bike? When did it run last?
No leaks
I think spark is fine as I can eventually get it to crank and run after 10 min of cranking. Ive had the bike for 2 years. Had it running a month ago but same issue....primes continuously and finally fires off and runs great. When I first bought it I replaced the FPR. I just checked the vacuum line and it is still good.
When I figure this out I am totally posting the result! There are other threads on this same issue and nobody has the bizalls to explain the fix. I will be swapping a buddies ecm to rule it out this coming weekend.
Please do report back in, that is the point of the forums anyway, to provide assistance. It helps others when the root cause is posted.
I couldn't stand it :eek: . I went over to my buds house and robbed his ECU this evening. Swapped it and ruled it out. Even with another working ECU it still just keeps priming along. I guess my next step is getting a fuel pump. I feel like i have ruled out everything but that. I really can't see that it would be the issue because the way I see it ....the fuel pump works or it does not. Something has to be dropping off the voltage to it seconds after key is on. BUT WHAT IS IT!....:crying:
Thoughts anyone???
How about swapping out some of the other electric bits? Maybe the relays, solenoid, etc.
I would look at the service manual and take a look at the bits that involve the fuel pump as a starting point.
Send your ECU to Carmo. I posted the link at the start of the convo.
They can test it and if it's working it's £50 or there abouts. If it's broken they can repair it.
Well I just eliminated the fuel pump being bad. I put my buddies on mine and does the same thing. Something else is making that fuel pump run continuously. I just don't know what else to try.:crap:
not the ecu, pump, relay,or regulator. What else to try???:huh:
Do you have a multimeter so you can test the voltages?
I got the schematic diagram for the bikes wiring and then traced it all to see what wasn't working
1 - 20 of 29 Posts
