Ok recently i replaced a missing spring on my f2 because it was leaking fuel into the engine hydro locking it severely. now when I run the bike it leaks through the vent and covers my left foot with gas so I am hoping that someone here can point me in the right direction for a fix or a rebuild kit. thank you all in advance.
Banned
Spring? Do you mean a spring inside #3? Even though they show it as the rubber booty holder, that more looks the vacuum pump body...
http://www.bikebandit.com/oem-parts/1993-honda-cbr600f2/o/m2042#sch7165
... #30 hose hooks up to a vacuum nipple off a carb, then down to the horizontal nipple #3. The vertical nipple of that body takes no hose. This is exposed to atmosphere. So, is that were it's coming out of?
I think you're stuck with buying lined out #1 if it is.
There is a rebuild kit for F2 petcocks. I've seen them somewhere but dont remember where. They cost somewhere around $40 from Honda I think. Which is a hell of alot cheaper than a new HONDA petcock, which is $180ish. You could try an ebay petcock from China, they're cheap, probably wont last long, but then again maybe it will.
Part #3 "cover set" is what you need, it supposed to have all the rubber pieces and diaphram and spring that you need to rebuild your petcock. You could also replace your petcock with one from a F3, they are not vacuum operated, supposed to be better. But when not running engine it is suggested to turn petcock to the OFF position. And you'd have to plug the vacuum port at the engine that would normally operate the F2 petcock. I think my F2 petcock is held together with rivets. If yours is like mine, I would drill out the rivets and replace with small screws made for metal.
Sorry Been a little busy. Yes Catch22 it is in #3 the diaphragm I believe needs a spring to keep pressure on it to keep fuel from flowing while the engine is off. I have been working on engines of all types for years and every type of diaphragm pump or shutoff I have seen have had a spring for back pressure. Coalminer frank my petcock was held together with screws and I was thinking that was the part I needed but I was unsure of if it came with everything I need. The fuel seems like it is leaking from the small vent hole on #3 that vents to the atmosphere.
