i just bought me a good ol 93 blade and i love everything about it..... except the headlights is there aftermarket or maybe diff model years that wont be so ugg?
the 98-99 fairings and lights fit! they look a lot better and work better!!! they cost alot thou!!! you can make the 08 cbr 1000rr race fairings fit, then put the light in!!! I have seen people use evey front you can think of!!! but if you want eazy!!! the 98-99 is the only one that is easy but it's not that easy!!! some info and pic's of other bikes!!! to fit the 99-98 front you need all this stuff
98-99 Headlight
98-99 Center position light
98-99 Fairing stay (you'll have to custom mount your gauges)
98-99 Mirror stay
98-99 mirrors
98-99 dash panels
98-99 windshield
98/99 upper inner radiator shrouds
98-99 lower center V
98-99 lower fairing panels (to mount the center V as it is taller on the 98-99 and meets up with the inner radiator shrouds
As you can see from the list above, none of your 92-94 parts are compatible with the 98-99 model, so this is more involved than when you first came here with your idea of what it would take. Good on your for asking the questions first before you attempt this conversion. It's not that hard to do, but you need the right parts.
you may all so want to change the tail too a gsxr tail looks good!!! so do the 929 and 954 tails! you can do those one's with your sub frame!!! made to fit! here are so peoples bikes the first one is a fox eye 900rr, with a 98-99 front with a gsxr tail!
