Since i bought this bike this temp needle has been getting worse. When sitting still no issues the needle moves as it should. Upon moving and increasing vibration the needle flickers back and forth for awhile and then evens out over time. But once stopping to a stand still and continuing, it will do it again.
Im thinking loose wire somewhere or a bad connection. Ill dig into it on my days off but i wanted to get peoples feedback if any were to be given.
Thanks in advance.
Thanks in advance.
Can you try swapping in another instrument cluster to see if it persists?
Nope I cannot, I have no spare parts. I wish i had some layin around though.
And you don't know anybody with a 900RR?
Blade,
I dont know anyone with a 900RR. So i cant use parts from peoples bikes to test. I will dig into it and see what i can find.
I was hoping someone had a similar issue and could give insight on it.
As it stands i have no spare parts and no access to use parts from other machines.
Re: --==RESOLVED==--93 CBR900RR Temp needle flickers
As i guessed it was a loose wire/connection
The gauge cluster connection easily pulled apart. Once i unplugged and made sure all wires were fine, pushed the connections back together very firmly and they clicked i knew they were good. Took it for a spin and the needle is as steady as they should be.
Thanks all.
