I picked up a '94 RR project to go along with the others in the garage. Front end, gauges, fairings and wiring harness (really chopped up) have been swapped to 96+, so it's going to be fun to get everything sorted out, but I like the challenge. Replaced the shredded rear fender, put on a rear wheel, threw a battery in it, cleaned up some of the wiring, and we have power, but starter won't turn over. There were only 5 bolts holding the alternator cover on, so I pulled that and found the 1st bit of carnage. After soaking it for a few days, I pulled the timing cover, tried to turn it over and the bolt snapped, so it's seized up good. Time to look for a donor engine...
