21 - 31 of 31 Posts
· Registered
Discussion Starter · #23 ·
Both bikes will be for sale soon to make some space for another project coming in.
Tire Wheel Fuel tank Automotive fuel system Vehicle
'94 - Clean FL title in my name
Definite project bike, engine was seized when I got it, but it's loose now.
Have most parts required for completion, will need engine rebuild.
'96 - Registered in my name in VT, have documents required for obtaining title
Incredibly clean, will need some engine work as after it warms up there is a knock/rattle. I drained the oil to check and there is a small trace of shavings, so whatever is wrong is either minor, or is a recent issue.
Feel free to PM me with questions on both/either bike as it will be a bit before I'm able to post up for sale ads with the details.
· Registered
Discussion Starter · #29 ·
Found a tool to remove the swingarm lock nut, so old swingarm and rear shock are out, replacements installed, along with new rear brakes. Wiring is up next, then adjust the valves and the engine can go in.
Wheel Automotive tire Tire Vehicle Tread
Tire Wheel Fuel tank Automotive lighting Automotive tire
Tire Wheel Automotive tire Bicycle tire Motor vehicle
· Registered
Discussion Starter · #31 ·
Big update since last posting, a few pics to share. Wiring harness rebuilt, valves checked, all remaining paint overspray from previous owner/s removed from frame. Engine's in the bike, wired, exhaust, stator, reg/rectifier, fuel pump, etc... Everything needed for the bike to run, and it's alive! :cool:
Converted speedo from front wheel cable driven to speed sensor from the sprocket cover as I have a '96 wiring harness and set of gauges that were on the bike when I first bought it. Test fit front cowl to make sure aftermarket bracket was good, decided to throw all of the plastics on to ensure they all line up before getting ready for paint.
21 - 31 of 31 Posts
