1 - 2 of 2 Posts
are there going to be any problems with this? do i need a 96 CDI? or 96 carbs? different wire harness? thanks
Banned
I've heard it works fine, same cdi is ok, just run the 95 carbs or don't worry about hooking up the throttle position sensor if running the 96 carbs. It's only a sensor and doesn't control anything in of itself. The CDI/ECU only controls the ignition ( coils ). The engine mounting hardware may be different on the 96, i'm not completely sure.
I'm sure someone here has done the swap and can tell you anything else i may have missed.
1 - 2 of 2 Posts
