1 - 11 of 11 Posts
Hi I have a 95 f3 and it takes a while to get it to start I don't know why. Before I put it away for winter I would push the start button and it would start right up. But now I will hold it for about 45-60 seconds before it will turn over and idol some times even longer and I don't know why it's doing it. I changed all the plugs and it has a new battery and it's charged with over 12 volts.
Can anyone help or give me any ideas what it could be?
could be the rectifier showing its age and breaking down under heat, but then again, yes check the fuel first thing...
i have a simalar problem but mine wont run unless i put gas down the carbs then it dies right away. i put new gas in it cleaned the carbs made sure the diaphrams are ok and they are. filter is clean. still cant figure it out
any ideas
1 - 11 of 11 Posts
