Have a 02 954, with 22k on clock, It's had a recent oil change, I've only just got it, so don't know its full history.
The problem I've got is, when I pull the clutch lever in, there is a tapping noise coming from under the clutch cover, this only happens with clutch pulled in, when it's in neutral with clutch out there in no noise. No loss of performance, and changes gear fine.
Once bike is up to temp, there is no noise.
This seems to be the opposite of most 954's I've had, as most rattle on idle, but then go away with clutch in.
Any Idea's, before I start pulling it apart.
