Have an 02 954 problem.
Last night on the way home from a ride the thing quit on me doing about 85 on the freeway,pulled the clutch in and started to pull over and it suddenly just fires right up. So I keep going and when I get to the tool booth and stop it dies,takes about five pushes of the starter button and then fires. About 5 minutes down the road it feels like it wants to quit but it doesn't feels like it just cuts out for a second and it jerks you forward and then is fine for a little while and then will do it again. Get it home after a couple more episodes of the feeling like it wants to quit and park it.
Fire it up this morning and take it for a spin and the same thing happens even shut off at a light but fired right back up.
No FI light came on, no smoke and it sounds and rides the same other then the cutting out and stalling... Any ideas?
Thanks.
Administrator
Most likely an intermittent connection somewhere. Start with the battery connections and go from there...:idunno:
I think I got it. The plug with the single red wire that runs beside the battery wasn't connected all the way...
