got a stock 929 with a blown motor and want to do a clean 954 swap. has anyone done this?
i heard that to do it PROPERLY, you need:
954 motor
954 fuel injection and FI wire harness
keep 929 gauges & handle bar switches, and front harness
any advice, suggestions, ect ect?
don't know personnaly if they will interchange or not, when honda changes year models, they shift alot around to change center of balance....good luck, sorry i can't help.
You don't require the 954 throttle bodies as the 929 ones will work just fine.
You can simply change the engine and leave everything else original if you wish.
