Hi! I don't know how to start..
I had an accident last year and I broke the stator cover and a little bit of the engine. I've replaced both parts, stator cover and the lower engine casing. Now, my problem is..the bike is starting, but it dies quickly after if i don't pull the throttle, no idle speed (if you know what i mean..i don't speak EN very well). My "rpm meter" shows exactly 5000 rpm, no matter what I do, full throttle or no throttle. The Fi light is always on, and the Oil light is blinking, on and on.
What seems to be the problem? Thanks!
PS. I have new spark plugs, new oil, gas too :rotfl:
Loose or poor connection of the MAP sensor vacuum tube
Faulty MAP sensor
if its just two blinks
or it can also be Blinks
Poor engine response when operating the throttle quickly
Loose or poor contact on TP sensor connector
Open or short circuit in TP sensor wire
•Faulty TP sensor
