Looking for some insight from some experienced 954rr owners...Reading old threads, this wasn't a very common issue circa '08-10...but by '14 the various cracked block issues were more commonly seen here.
I'm looking at buying an '03 954 (most prone to failure year) currently has this issue, though educated opinions are useful regardless.
According to the seller, the water jackets cracked and the bike was welded/fixed at a dealer in the past (have yet to verify)...but the heat from the weld damaged the headgasket, where coolant now apparently leaks from. Bike will start up and "run" but needs the hg done of course.
I don't buy the story, if the hg was damaged from a dealer weld, one would think that they would be responsible for that.
Aside from this, how incompetent would a welder have to be to do this and more importantly, how likely is it that the block needing the "typical" welding repair is still the issue, rather than the hg..as evidenced by the hg leak.?
What's my worst/best case scenario?
Worst, apocalyptic possibilities aside, is a replacement engine required.
Best- Would "just" a hg be a relative "win," that's still quite an extensive tear-down needed isn't it...
