Nope, it bolts straight in.i want to put a 954 rim in 1000rr forks will it fit? and will i have to change of the spacers or anything like that?
'04/'05 are 310mm discs, '06/'07 are 320mm.what yr 1000s are 10mm and what yrs are 20mm smaller ?
It doesn't matter what wheel you run.so if i was to run 04/05 1000rr forks and calipers on a 954 rim and discs, then id need 20mm spacers/risers for the calipers wouldnt i?
