I got a whole slew of mods done to mine but before I answer your question what are you trying to accomplish with the bike?
Just performance (increased hp?)
Want better suspension?
Braking?
What kind of riding do you normally do?
Discussion Starter · #3 ·
my riding is normaly on mountain open roads
with both fast and slow corners
i'm not only interested on HP
but rather a linear motor running
I also have on my bike somo other goods
some mechanical, and some only improve the
style of the bike, and they are:
KN air filter
slipper clutch
+2 rear sprocket
blue color chain (530)
steering damper
raised footpegs
integrated rear brake ligths and turn signals
custom paint job (camel replica)
goodridge brake lines (blue)
Brake and clutch levers (with a joint to bend)
brembo radial brake master cylinder
and other custom made mods
Land vehicle Tire Vehicle Automotive tire Spoke
Auto part Vehicle Engine
So i'm happy with my bike as it is
but i'm always looking to improve it in some areas
(from now on, mostly handling)
i didn't did anything yet to the suspensions
so, whats your advice??
Most of that gain you netted on the dyno was probably due to eliminating the HTEV, not from the ram air... especially since on a dyno you can't get the ram air effect.
Says who? Eddie brake, inersha (sp?) driven dynos (Dynojet 250i) have speed variable fans. 25% brake on the drum will also simulate your bike on the actual open road. You can get pretty exact with the newer dynos.
KN air filter
slipper clutch
+2 rear sprocket
steering damper
raised footpegs
I'd go with suspension upgrades ....
new fully adjustable rear shock (Ohlins, Penske, Elka, fox ect ect)
Replacment upgrade forks are nice but very pricy. You can do a complete Race Tech gold valve kit with new springs and heavier oil on your stock forks.
Upgrade your rotors .... Wave rotors ROCK!!
Lighter wheels with new bearings
These come to mind first but it really depends on your budget vs. what you are trying to acomplish.
I don't see anything listed about your exhaust .. what have you done there? Oh yeah .. get rid of the POS K&N air filter and get a BMC Race air filter.
If that were the type of dyno used that would be one thing. Even then, 'ram air' was never so simple as running tubes to the airbox - when Kawi was doing it with the zx's in the late 90's early 00's they had to do a lot of testing with airbox shape and such to get it to have any positive effects and it only then provided noticeable gains at high speeds. A set of snorkels run to an airbox that is not shaped with ram air in mind? Not trying to be a spoil-sport but I'm not a believer. I've done enough aero work with cars to know how precise things must be to have positive effects when dealing with airflow.
That I will agree with. I don't imagine the ram air system he has gave him much in the tune though I'm sure it was something. It is however a neat little, not often seen mode that makes his bike unique! The only one I'm pretty sure that gave the 954 any real gains was the hotboies carbon fiber airbox which was designed for the bike when it was run in AMA.
