Anyone know if is will fit? I was working on my sssa project yesterday and saw my old wheel and thought they might be the same size.
I think it depends on which model you're using but I don't think any of the VFR sprockets are the same pattern as the 929/954/1000RR.
Blade, bolt pattern or tooth pattern? Just wondering if I should waste my time and check it or not :)
Tooth pattern?
The tooth "pattern" or pitch is due to the chain you run, not the bike.
If the sprocket is in good condition then you can always re-drill it to fit the VFR hub.
