First post:hellobye: but I have decided to do a sssa on my 02 954. I just got the swingarm in and noticed that the brakes have 2 lines going to the rear caliper and there is some type of proportioning valve as well. Is this a problem anyone has run into or is it only with the newer vfrs? Can I just block off one of the return lines and run my stock master cylinder? Any help would be greatly appreciated
ya you can just block one off, one works the large center piston an the other works the two smaller pistons. An get rid if the abs unit u just run a new line from from the master cyl to the caliper i got a steel braided line 48" with removable ends an ran i thru the swing arm an honed out the hole on the top by the rear just a lil enought to fit the line thru this way u dont have to put the ugly chain guard back on
i blocked one off... you don't have as much stopping power, but its not that bad.
i snaked a SS line through the arm and thats the caliper i hooked it onto
