Hey All
Weird thing has started, switch on ignition, click on kill switch, nothing no fuel pump, couple of times, then it comes right, then the fuel pump sounds different, as if it drags a bit, (drags e.g the normal sound but slower) crazy, i know.
Sometimes, i switch the ignition on and kill switch, leave them both on for about 15 seconds, and the fuel pump automatically kicks in?
fuel pump relay / kill switch fault?
fuel pump noise due to it not starting and to much pressure in the line?
advice please guys.
H:eek:
Hey All
advice please guys.
H:eek:
BATTERY CHECKED?
sounds like a bad connection, check them all, try some wd40, if know joy there, turn all on when it does kick in check temp on relay, if its sticking it will be warm....
Thanks guy's .
New battery , approx 6 months, will check it anyways, also will check the connections, any ideas to the dragging noise on the fuel pump?
H
if its not getting enough juice it will drag, if there is enough juice then the primer could be on the way out...rare though.......
Pull the switch gear apart and have a look at the kill switch - they can at times play up (worth pulling apart)
