1 - 20 of 36 Posts
So my 02 954 has been having a problem with the blinkers. First it was when I turned the left blinker on it would stay on solid. Unless I would turn on the right one then go straight to the left blinker. Now sometime the indicator light on the cluster will blink but the lights do blink most of the time. I have the integrated led tail lights and the led blinkers on the front. Thanks for the help.
There are two options to fix the problem - adding power resistors to the circuit, or replacing the turn signal flasher relay.
An integrated tail light will NOT pass MOT - just have separate signals on the side and you'll be ok.
You need an electronic flasher relay - I used THIS one in my 929 and it's perfect.
1 - 20 of 36 Posts
