1 - 10 of 10 Posts
As the title states i need an upper nose fairing either silver or black preferrably silver. pm me, respnd to this, or text me 33o 414 7556
Hi diesel..are you still riding the 954- you said youbalmost had a tank slapper situation. I need some input as i own the 954 only 7 mths. I hv conflicting infos. Some local ex 954 claimed it dont need a damper as it has steady cornering. But some mags claimed it is definite for 954- i hv change forks internals and rear spring to ohlins. I read that a frnt 17 inch rim helps as original was a 16- is this true.? did you almost had the head shake out of a corner on uneven surface? any info will help. I tot of fixing a sxc sprint damper which look neat. Whats your advice. Any info will be much appreciated . I am planning a track day in october this year. Thanks
just over the crests of hills and especially on the crests of hills on uneven bumpy roads the front end will lift and wobble. sometimes in a straight line crackin it hard the front end likes to pull to one or the other side when its in the air. a steering stabilizer is a must on one of these things, i havent and wont be topping this bike out or hittin the track with it until i have one.
its like people set these things on their mantle when they part out or sell their bike, nobody gets rid of these pieces of plastic and i neeeeed neeeeeeeeed neeeeeeeeeeeed one!
1 - 10 of 10 Posts
