One of the last projects I want to get done before spring rides and track days is to check the valves.
The bike currently has 13,000 miles and while I don't hear a lot of clacking around coming from the cyl head, I just want to make sure everything is good to go.
So here's the issue.
The service manual calls for a special tool to hold the CCT all the way in after you are supposed to crank down the CCT.
I'm wondering how important that tool is and if I really need to use something like that, then is there any way to fabricate a replacement as I don't want to wait /spend for the Honda tool.
I figure there has got to be a work aound for this.
'Lil help?
Yeah, I saw your thread in the KB.
They've got to be pretty similar, huh? (929 & 954)
Thanks, I'll give it a shot.
I just Checked Mine Two Week's Ago ( 20,000 km ) Had two Tight one's I found the wireing harness a bit of a Pain to get aroung the cross-member at the top of the frame :thumbd: I also had a *Throttle body Sincronization * done after it was Back Togethier !!
You only need the tool if you have to adjust the valves.
I fabricated mine with tin snips and an old electrical box. The service manual has good instructions for making that little tool.
