Hi there guyz, i got a 954. and got a problem about RPM meter. it's not working, but the other systems are all fine! my technichan lookin' the wire system and said me "maybe the problem is just wires, but bad option is, it could be from brain" i guess 954s and similar oldie fireblades count the RPM from plugs. Each lightning is going thru RPM meter.
So what could be? Brain? Plugs? or just wires?
is there any1 who got this problem or solved this problem.?
thanks a lot fellas.
Best regards.:huh:
get online and download a service manual. it sould have some trouble shooting guides to help you find the problem. like he said it could be any of the three. wires, ecu, or broken gauge. when you say other systems are working do you mean the temp and speedometer are both working on the cluster and just the tach doesnt work? gauges all light up? or they are all dead?
yes they all working, temp, gas light, speed, signal and FI lights. everything workin. just RPM's not..
