1 - 1 of 1 Posts
hi guys I need your help..
My 954 do not start. I've checked nearly everything- MAP, IAT, TP, Fuel lines, fuel pressure regulator. Ive checked FI errors- and it shows 18 -camshaft sensor BUT, after reseting all errors using jumper wire, and after restarting ignition once again it is not showing this error again. What is more weird- when I turn the key on, and change the ignition switch for 'on' MIL light is on for 5-6 seconds, then it starts to blink constantly (long single blinks)- and it blinks untill I turn off the ignition switch. When I put the jumper in to see what is the error code, MIL light is not blinking at all- so I assume it says that there is no errors left...
It has fuel, injectors are working, there is spark, so what is the problem? All sensors seem to work properly- I haven't checked camshaft sensor yet...
1 - 1 of 1 Posts
