Hey all. Rode the bike to work and back. Gets ridden twice a week to work and I ride my r1 now the rest of the time. Runs great. Starts great. Parked it.. 2 days later, no fuel pump priming. Swapped around all the relays. They all click when put In that position. I tried moving around and reconnecting ground blocks and disconnecting my pc3 since both those things have affected fuel pump priming before. The pc3 got water in the plug before. No water this time. No difference. Fuses all good. I saw a post about servo causing this issue. I tried disconnecting the servo and the plug was giving me a real hard time. Might have to take the tank off to get it. I also attached another battery to the bike. I haven't checked it its not getting spark either but I have a feeling that's the case cus it just had not sounded like anything but starter motor. Not a single glug lug lug. Just got to work... hoping you give me ideas to Try for tonight.
Ps there was ONE symptom that was odd but could be unrelated. Since I've bought the bike it had had a weird hesitation at warm idle. It goes: gluglugluglug_luggluglu... and it happens maybe once or twice in an hours time of commuting. The last day I rode it, it did it 3 times in a row right off the back of each other which it had never done before. It did it a couple more times also. I had run the bike almost bone dry and filled it up st the station and it did it right after leaving the station.
i think if I cant isolate anything I might end up buying a replacement harness and fuel pump and relays and call it a day lol. But im broooke right now. Thank you
