Hello everyone,
The speedo on my bike went out and I have no idea what speed I am traveling. The light blinks 11 times, which means either a faulty speed sensor or bad connection. What I am not sure of is where this sensor is located? How do I get to it and what does it look like? This way I can check the connection on the bike before ordering a new sensor.
Thanks for all input.
Hello everyone,
On top of the transmission, the test process should be detailed in the manual.
Discussion Starter · #3 ·
What do I have to take off to get there though? Do I go from the top by taking the tank off? Or can I access it from the sides?
First, I would check it at the connector.
If it fails then pull the tank and check at the sensor itself to rule out bad wiring.
