Hello all,
I am a new owner of an 02 954rr. I have always wanted a fireblade. I have owned a vstar 650, then a ninja 500, then a vfr 800, then another vfr 800, then a sprint st 1050, and now my very own fireblade. Hallelujah.
However we have some issues.
Firstly, the bike came with a power commander 3, and an Arrow exhaust. I think it is at least a half system, if not a full system. The can is freaking massive. I put my delkevic 8 inch carbon fiber on it today and loved it in ways but it also seemed to make it even more obvious that not all is right since I could hear the engine better while riding.
22k miles.
I have been loading tunes today that seem relevant to my setup to no joy.
Here are my issues.
I hear a sowing machine going on, and assume it may be a cam chain tensioner. It sounds a lot like when I had the same issue on my ninja 500. Tick tick tick tick...
But also, it bogs at take off. I have to add a bunch of throttle, then quickly ease off, then adjust to riding normal, or it will almost fall on its face and stall. Increasing the "low" setting on the power commander to way up seems to help a bit, but does not solve all of the issues at all and only gives maybe a 35%-40% improvement. It takes off nothing whatsoever like my triumph 1050 and is currently a real pain in the ass to deal with in traffic due to it's ailment.
Alas, finally. Once it heats up, it will almost die on idle. When I get to a light, it will go tick to a silence and then continue. At a light it may happen 3 times, unless I give it constant throttle.
Finally, it has seemingly a delay to throttle. I twist and it seems to ramp up to where I am actually leading it to. When I put my delkevic on it made it very clear that it all around is not running optimally and I am pretty sure my Sprint st 1050 with +1 sprocket is all around quicker right now. It certainly is worlds better responsive.
Please help lead me to water... I am fighting for time on my days off to work on things and am really frustrated. If someone could point me to things to check I would be very grateful. Could a lot of this be vacuum related? I ask this since richening up the low seems to help a bit. Need to check the air box soon and am guessing trying out a manual tensioner. Maybe try the bike without the power commander.
PS if I load the "no map" tune file for power commander, is this the same as running the bike without the power commander? Or is it just empty and void and will result in nothing good without manual entry for all fields?
Thank you
22k miles.
Here are my issues.
Thank you
