1 - 1 of 1 Posts
Hello all and thanks for having me.
i recently purchased a 97 firebalde and found the tank had a leak. When i went to fix it i found... a bit more than a leak (pic attached). i found a hole and patched with a JB steel stick, did some body work and got her all painted up and now she's started leaking again.
since there was so much damage, i'm wondering if there's a lot of thin metal or cracks i couldn't find (inserted a light in the tank in a dark room) and the tank is a goner.
OEM tanks are $750+. i've read the 98-99 tanks will also fit (same mounting and air box clearance). does anyone know if the 00-02 tanks will also fit?
i'm looking for anything to get her back on the road. any help is greatly appreciated.
1 - 1 of 1 Posts
