Hi guys, I need your help. I have a 97 rrv engine in a track car, don't hate me 🙂. Couldn't resist the great engineering in bike engines. It has proved to be bomb proof over the years, only needing a new clutch. The car was running for many years and then put up on bricks 7 years ago while I was living elsewhere. What with all that is going on at the moment I decided to rebuild her. I seem to have an electrical problem. No alarms, pre pink wire and all safety devices, clutch, stand etc bypassed. I am getting no spark.
I have tested and replaced coil packs and leads. I have 12v to both coils and have put a bulb between the pulse wire coming from the ecu and the positive on the battery. The bulb lights up as you would expect so there is a negative pulse coming from ecu to coil but still no spark. Help, what am I missing? Thanks in advance.
