1 - 20 of 43 Posts
New in package Ignition advancer +4, steel brake lines, Rear Brake pads. Newer front and rear sprocket one down two up, DID racing chain these have less than 600 miles. Used air box with K&N air filter, windshield, Rear shock, 2 front brake rotors, Rear brake rotor, factory brake lines, brake and clutch lever, inner plastics, rear seat, electric fan (radiator bad), Chrome chain guards, polished aluminum sliders, coils, factory front blinkers, Shifter rod and lever, custom made polished CBR 900 RR side plastic brackets, Triple tree and ignition with key, coolant reservoir and original owners manual along with some smaller miscellaneous parts.
call/text 920 217 6530 or PM me, but perfer call text with offer shipped
Location - Green Bay Wi, 54302
$350 for all parts or make offer for something individual :)
what's left - - - - - -
Both front rotors – no hardware
Full air box, with k&n air filter
Whole master assembly with lines – broken holder attachment
Radiator- unsure – working electric fan
Triple tree/ ignition,with wires including key
Both inner fenders
Both panel covers – right(fuse)
Brand new steel braided lines, with banjo bolts
Rear shock & res. – top bolt included
ECU/ECM
Coolant res.
Shift lever/rode/ heel guard -bracket broke
Rear brake assembly – stock – whole
Brand new rear brake pads
Windscreen – clean – minor stress cracks
Front seat
Ignition advancer - +4
Owners manual
Throttle tube/grip
Misc bolts/nuts/axle/
Stock blinkers
Can you list out prices for the:
Steel brake lines
Stock blinkers (front and back)
Clutch and brake levers
Inner plastics (also, can you describe what these are. Do the fairings fit onto these and on the inside of the front fairing?)
Thanks.
Discussion Starter #13
Steel brake lines
Thanks.
can you give me a call 920 217 6530
1 - 20 of 43 Posts
