1 - 9 of 9 Posts
Hello to all, it's time for fresh chain and sprockets on my 98 f3. Do you guys run stock 15 - 43 with a 525 or -1 -?
I do a lot of freeway driving... Shop recommends -1 (14) -5 (38). what do you think?
Heeza Y Zasch
When I used to do a LOT of highway riding, I chose a +1F -3R setup (with new chain). I was quite pleased with the lower RPMs at speed, increased fuel economy, and "extended" mileage I'd get from a tank of fuel.
Unless you're looking to set a new land-speed record, the aforementioned -1F -5R sounds a bit much :hmm: unless they're looking to sell you a new clutch as well :twocents:
Heeza Y Zasch
Nothing significant with the +1/-3... but I surely wouldn't recommend many "in town" shenanigans with that set-up :nono:
So I've heard it said that a change of 1 tooth front is equivalent to 3 on the rear.
Following that reasoning, your ratio is the same as stock.
You said lower rpms at speed now - so you gained some top-end, but lost just a little power or quickness at lower rpms?
Since most folks go the opposite way, like my -1+2, I'm just trying to wrap my head around your setup. I understand your intent was different than mine, but your end choice seems like it would have minimal effect. How big of a change was it?
To figure out what you want and compare it to what you have, divide the "rear" by the "front". 43 divide by 15 = 2.87
The shop recommendation 38 divide be 14 = 2.71. Not a whole lot of difference. Save your money, get the 520 conversion, 525 aint worth it. More options available with 530 or 520. Now a 42 rear with a 16 front. only 1 tooth difference on each end than stock = 2.63.
Heeza Y Zasch
I've heard that too Jon... dropping one in the front is like adding three in the rear.
Almost... adding one in the front was like dropping 3 in the rear. That, accompanied by the 40T rear (-3) would be like having a 37T rear.
as per @coalminer frank's formula:
16/43= 2.687 (OEM)
17/40= 2.353 (Casey's old highway set-up)
16/37= 2.312 (just for reference. never heard of a 37T rear)
15/45= 3.000 (Casey's RR3)
15/47= 3.133 (Casey's RR2)
yup. :thumb:
That was almost 10 years ago, mi amigo. I remember it being "lethargic" when getting back on the on-ramps after fuel fill-ups during long trips. Although while on the Interstates, my memory is of less vibration in the bars and MsPG being in the upper 40s.
Currently my RR2 is 15/47 (-1/+4) and my RR3 is 15/45. Both with 520 "conversions".
Heeza Y Zasch
I know I typed this... but for some reason I READ it as +1/-5 :bonk:
1 - 9 of 9 Posts
