Can anyone tell me what this is called?
And anyone have one to sell, with the connector too?
Thank you. Beside the corrosion and melted plastic, it also rattles inside.
When I put the key in the ignition, it's completely dead. No lights, nothing, even when I tried to jump it. Could the starter solenoid be the culprit?
Yes.
When you replace it, you should also be careful regarding the regulator, stator and battery. If the solenoid shorted it could have melted any or all of those too. Start by cleaning and silicon greasing (not mineral grease!) all associated plugs, charging the battery and checking if it holds charge.
Thanks for the advice, I have the part ordered, should be here in two days. I'll post up results.
Thanks again!
