1 - 20 of 21 Posts
I have a set of EBC HH sintered pads coming for the front of the 1000RR and I was wondering if I shouild be doing anything to "prep" the rotors? I currently have a set of GALFER pads on and I don't like them at all, I have to say that I liked the stockers better, but I am wondering if it was from a lack of prep on my part? what do you guys think?
do my rotors need to be sanded or sand blasted? what do you do to prep yours? :idunno:
If you go sintered (stock) to non-sintered, you have to beed blast the rotors. You shouldn't need to do anything if you go from non-sintered to sintered.
Since I went from sintered to sintered, I just did a very light sanding and cleaned the rotors with brake cleaner. I've had great luck with the stock pads on my 929. I had Galfers because they came in a kit with the lines, but I didn't particularly care for them.
Great thanks for the quick replys guys(and gal;) ) I had very good luck with the factory pads on this one and the 929, I just thought that I would try and upgrade since I have braided lines too:idunno: I will try a light sanding just to be sure and go from there:thumb:
Just get really, really fine sandpaper. I found fine in the basement, I think it was 120 grit, but it seemed to scratch, so I really didn't sand very much!
600+ is fine, I would try 1200. 120 is pretty harsh.
EDIT: In general if the sand paper is wet/dry using it wet is equivalent to one grade finer
+1 on the Scotchbrite pad. A must have for the toolbox. Love the simple little things.
Administrator
Scotchbrite here, too. Use acetone to clean the rotor...works better than brake cleaner.
maybe too soon to ask, how are the HRC pads? I need to do my brakes and I now need to find some decent pads. Or should I just get stockers?
Vesrah's are pretty good. Either RJL's or SRJL's<--if you've got that kinda cash.
Thanks for the help, just got the bike so I have no cash LOL hoping to spend less then 100$ I guess i just need something that will do the job, the bike wont see any hard riding for a while as it's my first bike. :)
1 - 20 of 21 Posts
