I'm thinking about removing the flapper in my air box, blocking off the pair system, and removing the butterly in my exhaust.... I know this will throw a code, what did some of you do to get rid of the codes??
The flapper and valve wont throw a code unless you also remove the servo that controls them.
If you decide to remove the servo, youll get code 34 & 35.
Ok, so only the servo will throw a code? What did you do to get rid of or correct the code after removing it?
I'm not aware that anybody has made anything that will remove the error code.
It has no other effect though so isn't worth putting the effort into making it go away.
