Ok, dicided to take the hard drive out of one of my computers and add it to another since the power supply and processor took a dump in it.
So, the drive is compatible. I have actually swapped them and had the comp boot up with either one.
Only thing I am not sure about is how the computer will react when i boot up after adding this other hard drive in there since it also has a OS loaded on it. All I really want to do is erase everything and then use is to put all my music and movies on when i start doing some editing. Anything I should do at startup to just go ahead and format it or will it boot up fine and I can go thru install from there?
In your Bios there is a primary drive (the current one should be selected) and it will try it first, find and OS and boot, no worries. After copying the data you can have more drive space or create a Linux system for dual booting :thumb:
If it selects the old drive just swap the bios (unlikely)
Getsome,
If you are putting it on the same IDE cable as the other, you might have to make it a slave. Look for jumpers on the back. As long as you don't pin it as master and have the other drive as master as well, it should just show up on your computer as another drive with data on it. The only real reason to reformat it would be to reclaim the space the OS loaded onto that drive is taking up.
You could get fancy, and have a dual boot system where your pc can boot either the current hard drive, or this drive, but that's a little more involved. For now, just plug it in, and boot up. As long as you don't touch your current drive, it should just show up as extra space.
OK, i figured it would be good but once i move the jumper to slave and install then i should just beable to delete all finles on the that drive including the extra windows OS then. just wanted to make sure my comp wouldn't do anything stupid when i did it. never threw another internal drive in before..
now just to figure out which of the other 3 sets of pins is the correct one to make it the slave. they aren't marked...
go to the drive manufacturer most have that online. Also IF you are removing the data I recommend a format. That way extra errors, spyware, virii are deleted. Clean slate.
