Does anyone know a good website were it gives you step my step for this mod? because it seems like a easy mod i could do myself and save some money by not taking it to the shop to get it done..or can some one just tell me how to do it on this thread.
well you can either remove the flapper, which involves a bit of work, there is a link on here on how to do it, or you can do as i did and just pull the flapper cable to the max and tie it off, works for me, your call just take off tank then airbox cover and you will see for your self that its pretty straight forward to do:thumb:
1) Open air box
2) Unscrew and remove entire flapper assembly
3) Put screws back in
4) Unhook cable from air box and unhook it from the exhaust servo.
**DO NOT UNPLUG OR PLAY WITH THE EXHAUST SERVO AT ALL**
5) Silicon or RTV hole for cable in airbow closed
You have no completed the "flapper mod"
