As far as I'm aware it's a simple bolt-in swap but you'd expect to have to re-shim the valve clearances.
I like the 954 throttle bodies but I swapped exhaust systems at the same time I swapped the throttle bodies so I can't tell you exactly how much difference they make on their own.
