my speedo is confusing it does this and this is all it does. But on another bike it works fine.
Does it still do it when bike is running? is battery good , have you checked connectors and earths?
Yes still does it when running and ive checked everything there is to i believe. I know its a long shot but could it be because a open circuit in my blinker because I have no fronts.
Hi . would check the Grey connector to the front of the bike and look closely at the Black/Brown wire from the fuse box to the LCD Panel and the Vehicle Speed Sensor , check for loose fitting ;)
107848
I would say yes, as the front blinkers are also running lights, so there is probably an interruption in power and ground for the speedo readout.
