Hi Fellow Blade lovers.. :)
Im in the process of converting my 900 to a new front. I have bought some 929 forks, and im now looking for the lower yoke.
So my question is does the 929 and 954 have the same yokes? Or will only the 929 yokes work?
And should i go for 929 or 954 brakes? i can see there is a difference in piston size..
Any input is appreciatet :)
Kind regards from Denmark :)
What I've found while researching the RC51 fork swap for my 919 is that the 929/954 yokes are interchangeable.
The calipers have different sized pistons but are externally identical, as long as you use the matching master cylinder you'll be fine
Hi :) Thanks for you answers :) So the 929 breakes as good as the 954?
My own master needs rebuilding, and I wanted to do an upgrade :) Thats why im looking at 954 breakes :)
Perfect with the yokes, ill try to find a cheap one :)
Ohh and the NeXT problem... I have a NC40 frontwheel on the sc28 atm. and the 954 rotors are 330mm is it posible to fit 330discs on the nc30 Wheel, do anyone know the bolt pattern size on a cbr 929/954?
110mm bolt circle
From the Metal Gear website
Outside Diameter330Inside Diameter94Bolt Hole Circumference110Bolt Hole Quantity6Bolt Hole Size6.5Thickness4.5Minimum Thickness3.5Offset12.5Type of Bolt HolesSTRAIGHT
Ok thanks :)
So I need an SP1 front Wheel, or make some special discs for my Wheels..
Thanks for your help :)
