are other oem 954 gauge clusters plug and play?
894 Views 7 Replies 5 Participants Last post by  sjduxa
The guy I bought my 954 from put a aftermarket guage cluster on and I hate it. I want to get a oem one off eBay but before I do that, are they plug and play? I don’t think he removed the speedo sensor from tranny. And not sure how the Rpms work if it’s another sensor or what. Same thing with low fuel light. Mostly just want speedo and rpms. Can I plug a oem one in and will it work without having to do anything else given the fact the sensors are still there?
Depends on how much he butchered the wiring harness, was the bike for track use , did the indicators work as the indicator relay is in the combination meter, so he might have installed a relay, other than that they are plug and play, depending on the connector
Indicators were taken off the bike but the connections are there still
Mileage will be whatever is on the 2nd hand cluster, otherwise plug n play
Awesome good to hear. Apparently the speedo sensor is still there, I’m just more so worried that the temp guage and rpms won’t work. From what the last owner told me he hasn’t pulled any sensors out when he installed the aftermarket cluster.
  • Like
Reactions: 1
It sounds like the OEM should plug and play. Do that and then let us know. Should be easy enough to help out with all of the knowledge here ;)
Yeah absolutely! It should be here by Saturday so I’ll let y’all know for sure. Again I appreciate that advice!
  • Like
Reactions: 1
So I've been investigating eliminating my stock front lamp and changing out my group with something somewhat less jumbled yet haven't at any point seen anything about somebody trading out their bunches for some secondary selling ones. Indeed, even the Chinese ones will do; I simply need to transform them out to update the vibe of the bicycle according to the driver's perspective as well as consolidate a couple of numbskull lights in there, for example, a clock or in any event, coordinating a fuel level check or a stuff pointer. I realize not all choices are a plausible thought however it appears to be odd that there are such countless individuals with custom F2s and nobody specifies anything regarding this matter. (Or on the other hand perhaps I can't look through alright) one way or another thanks ahead of time for the info and I trust this leads me some place great.
192.168.100.1 192.168.1.1
