1 - 2 of 2 Posts
Hello everyone , as autumn is well and truly here , I’ve gone back to 16/43 for winter , BUT , the blade sat outside for 5 mins during a light rain shower and the poxy misfire returned again , this bike is crap when water is concerned , anyways she still went out for a run and after a short time the misfire disappeared and what a lovely run out that was , wet/dry plus lots of leaves on the roads from our uk trees , if I can locate that misfire spot she’ll be good for winter use , lovely jubbly
Must be something simple shorting the system if it was only a light shower. I'm guessing you've done all the superficial checks like plug leads etc. I wonder if a good spray with WD40 or similar around the underside tank area might help? Might not cure if, but if the problem didn't occur again, you've started a process of elimination.
1 - 2 of 2 Posts
