1 - 9 of 9 Posts
I have no experience with synthetic seals, but as i would imagine they are made of silicone.
Rubber will age, dry out then eventually crack.
I work in an industrial facility and most oil seals on our equipment are the rubber type, and usually fair pretty well since they are not exposed to UV light from the sun.
being that your oil seals on the forks are below the dust shields either one should last for a while.
Discussion Starter · #4 ·
My 929 seals (Honda) lasted 17000 miles. Then I tried Italian seal from Parts Unlimited they lasted 10000 miles / 18 months...not happy with that!
There was a post with a link to Pyramid Parts for seals (rubber) cost 18.00 shipped. was hoping someone has tried the Pyramid's.
Considering how rarely you need to replace fork seals I would always recommend staying with OEM seals.
The only reason to go aftermarket is if you can't get OEM.
I just replaced my fork seals with the OEM Honda ones. Everyone I talked to recommended the same thing. BTW, it was an easy job. I did take them to the dealer for them so bang in the new seals though (with their fork seal driver), but it only took them 2 mins and they did it for free.
Discussion Starter · #9 ·
Your lucky I do my forks & take them to the Honda shop,cost 10.00..I am going to make the PVC seal installer tool & try it,saves a trip to the shop. Guess I'll go with OEM.
1 - 9 of 9 Posts
