1 - 2 of 2 Posts
What would be the best stock map (till i get a custom one) 05 1krr
bmc filters scorpian slipon flapper mod Im guessing erion with slipon map??
Im getting a Pc tomarrow is their any tips you guys have for A/F ratio heard of a couple people adding stuff to their stock map
Thanks in advance
if you go to the site that rhymes with 1000barbar.com they have a map database that has a bunch of custom maps that people have been nice enough to share with others...just look through and find a couple that have similar mods to yours and test them out...then just sitvk with the best fit for your riding style...
usually when you get a custom map the tuning pro will start with a map from the DJ website and then modify it by doing dyno runs and adjusting the A/F until it makes the best power..you could try this yoursewlf if you have a way to measure the A/F but its easier said than done...the same thing is done with the autotune..you start with one of the DJ maps and then the autotune makes adjustments according to the A/F but it has no way of knowing what A/F makes the most power...so it just tunes to whatever a/f is preset...which is why a custom tune is the best option..
1 - 2 of 2 Posts
