Edit: I am a retard. There is no problem.
Original post:
Ello,
So I installed the bestem undertail for my 954rr. : Honda CBR954RR Undertail 2002-2003 Black
It is absolutely beautiful. I love it even more than I thought I would. And the woes of hard install/poor fitting? Idk man, fit perfect for me. So long as I fix this one issue.
When I installed I thought it was weird that it simply says to connect the led lights, and does not mention a relay. When I used my previous led blinkers on the stock undertail it required relays. But I figured, I will do things by the book first, and use my own reasoning later so long as I followed original instructions first. To my surprise, the turn signals blink fine, they dont go solid like my other ones did... everything looks fine... except the right running light is about 65% brightness of the left running light. Once, I saw it just magically go to full brightness. I assumed then that there was a short somewhere. The wires do nothing, no short. Re-soldered and played around and found nothing. The right blinker, right brake light, all look fine.
But then I noticed, when I turned my high beams on, the right running light drops to like 30% brightness. It gets really dim. I am using a white LED low beam and I have stock yellow halogens running on the high beams.
Do I need resistors? On the running? Is it my rectifier? Did I commit unspeakable stupidity? Does my new undertail eat the poopoo?
I have not run the bike for a while, looked at the tail while running. I have only looked at the tail with the key on and also having just started the bike, and no visible change.
Please send help. I know nothing and barely follow instructions.
Thank you! =)
Original post:
Ello,
Thank you! =)
