I was getting my 93 cbr 900 winter ready and i noticed that it was running really hot. Was a little more than 3/4 of the way to overheating. And it was just sitting in the garage idling normally. What could be the problem? The bike has been sitting for 2 months if that matters.
Thanks in advance guys.
Motorcycles are meant to be ridden - sportbikes fully encased in plastics hate sitting around in one place more than most. Unless it's actually overheating when stationary, don't worry about it.
Has it never run that hot at idle before? Like the other poster said, a lot of sportbikes (a lot of bikes in general actually) get pretty hot when just sitting. I know that 954's get pretty damn hot just idling (upwards of 230F on a warm day). I'd assume that your 900 would be similar? If it is indeed much higher than what you've seen before, I would suggest starting with flushing the coolant if it hasn't been done for awhile.
Sounds just fine.
If the fan wasn't on then it's nowhere near overheating.
My digital readout bounces from 220*F to 230*F on a 70*F day. Drops back down to 175*F- 185*F range when back on the road. You're doing just fine. Overheating or your red range is probably around 260*F
